Screamin' Eagle Smart Tune PRO Automatic Tuning Module
Hey everybody, I am new to this forum.
I have been looking for a forum like this, when google cant help me anymore.
I have a 17` Low Rider S 110, with the stage 4 117 kit.
Running the super tuner software with stock nb o2 sensors and open loop.
Closed loop only allows afr 14,6.
Will this new kit; Screamin' Eagle Smart Tune PRO Automatic Tuning Module
allow me to give me; say 13,5 afr in closed loop?
Will the super tuner recognize this controller and bald out the closed loop?
Thanks
Thanks
Well, I connected this super duper atm to this bike.
2017 Low Rider S with stage 4. Did not work at all. Picked wideband sensor in meny, but only thing happens is a bike running **** and constant error code on both my o2 sensors.
Supposed to be plug N play??
Tried the updated map to, same issue.
Could it be cause i have a pro super tuner Not street tuner?
I'm running the super tuner and not the pro tuner also and it's definitely plug & play. If the ECM is not recognizing your wide band 02 sensors I would start there. Make sure they are attached properly and secured to the head pipes (I'm running Rinehart TD's). I would then make sure the connectors that link the ATM to the 02 sensors are properly secured. Final step would be to verify you are running the latest calibration (last 2 digits should be 05) of the wide band map for your configuration. When you open the super tuner software it should alert you to this mandatory update and inform you that you must copy and paste any of the data from your calibrations that end in 04 into the new calibration that ends in 05. What I had to do is load the new 05 map calibration to the ECM. Once I did that I pulled the file that I just loaded to the ECM and merged data values from the last version of the 04 calibration and then flashed that version to the ECM. Not to state the obvious but If your error code is being thrown by the 02 sensors that's where your issue is. Hope this helps
Thanks for the reply. I have done all this.
When i enter toolbox, system info, it still says ECM Wideband Enabled : No.
Any way to active this?
Calibration id 621shdw03-00
Software 11.000
Software 11.000
Software 11.000
Software 11.000
Rear sensor working like it should, but front did not regulate at all, steady volt all the time. Tried switching location on front & rear sensor, still the same error code on front sensor.
Spending hours trying to fix a problem that actually is hardware problems. Just seen another bike, and it was plug & play on that one too with the tuner.
Not sure if it would be the brand of headers but it well could be. As I said I'm not running HD SE headers I'm running Rineharts. If all things check out I'd try to return it as it does seem like some type of hardware malfunction. I'm sorry about troubles glad you kinda got it figured out.
