Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
If the system is set up to use the wide-band O2 sensors (18mm thread vs 12mm thread for the narrow-band), then you should be OK to convert to them. The factory narrow-band O2 sensors adjust for idle, and low load conditions, and high load and full throttle is controlled by hard programming.
