2015 fxdb starting with ignition OFF
Hey all, it appears that my Street bobs ignition has been bypassed somehow.
The bike starts in ignition, acc and off position. I pulled the plug from the ignition switch and even open circuited the bike still starts.
Iv tried to check for codes and/or reset it but as the ignition appears to be stuck in the on position I'm not sure how to do this. Any ideas on what I have done or how to fix this?
The only work I have done recently is change the headlight. Just a plug in LED unit and changed the grips. I had the switch housing hanging but didn't make or break connections.
i must have pinched the wires when I reinstalled the tank console after some work a while ago... I'm an idiot.
The worst damaged was the CAN high and the power.
so I think I short between the 2 or ground on the tank may have occurred.
Iv repaired the wires and still have the issue. Is there some kind of a reset I can try or if the issue was fixed would the problem just resolve it's self?
From what I have read my bike may be in fail safe mode as I haven't tried to ride it yet, just started it. I will check this when I get home.
