FP3 - keep getting p1010 dtc
Have the same issue p1010,along with check engine light, comes on @ start and lingers longer than before FP3 and goes out only to come back on a few seconds later,after a bit of throttles it goes off and seems to stay off until the next cold start.
Contacted V&H they sent a new map,same issue but recommend riding a full tank first ,so will see.
Very hard to contact Vance,took over 1.5 to talk online chat and flash ecm to them and get new map download back,crazy slow.
AT first I thought they just sent original oem flash,because it felt like before FP3,but did seem to improve over the afternoon ????only time and a full tank will tell.
I hope you're able to resolve the issues you're experiencing... hopefully it'll be something simple in the end. Please share any solutions with the group so others can try the same thing.
For the cost and popularity of the product, you expect no issues... but I'm sure there are a lot of variables in the way folks have configured their rides and that can be problematic when working with computers.
Ride Safely!
John.
Ride Safely!
John.
That's good news for u ,gremlins ?Going to clear the code tomorrow see if it comes back.One thing if any one wants to comment.I installed a new ac @ the same time I received my fp3,its been flashed with the new ac,but it was like a three piece unit with gaskets,wonder if air is somehow getting in between gaskets( i checked it today everything tight) and causing an o2 sensor problem and triggering engine light?
Also anyone,V&H downloaded to my phone a new map after I sent them my ECM data 2 days ago,I flashed my bike light also remains,but do I have to keep fp3 plugged in,they said to run a full tank with this map,so does this new map have a autotune program included ,why run a full tank ? why would it change anything?
Seems the instructions suggested running a tank on the 'canned map" then run with auto-tune.
You can auto-tune any map. While auto-tuning the engine won't run its best... not bad, but you might notice it idles a bit rough. After you flash the auto-tuned map, it'll idle better and you'll see the benefits of the auto-tune. After youre done auto-tuning, you can take the FP3 off... it doesn't need to be installed all the time... or you can leave it... your choice. It seems some (myself included) have received trouble codes if it's left on.
Good Luck and Ride Safely!
John.
John.
trigger1911
08-23-2008 07:58 PM
