X14ied for stage 1?
I put python slip on's on my '15 slim an the popping was pretty bad on decel. I picked up some Xied's used on here an they probably cut it in half or more.So for me they didn't totally cure the problem but made an improvement an made the bike easier to live with. with a tuner like the FP3 you flash a tune to adjust for your changes an your stock tune is stored in the tuner an you just flash it back if you have a emission inspection. I sold my xied when I got a flash tuner so if you pick them up an decide to move on you can do the same. Flash tuners get married to the bike so they can't be sold like the ad on products.
Using products designed to try to fool the ECM into running the bike richer than calibrated for will always cause ill-running issues because lying to the ECM will not accomplish what the user assumes.
Bob
Unfortunately there is an awful lot of misleading info around HDF and the internet. Nothing has changed - when I bought my first Harley back in the 1970s owners fitted slash-cuts and an S&S air cleaner with the same consequences that EFI owners suffer these days! In both cases there is no substitute for using suitable components and tuning the bike right.
I have an PC3 on my 06 and true dual exhaust. I have baffles and do have a decent tune on it and it works well.
I just added the Xied to my Wife's 08 Softail and all she has is an intake and slip on Rush pipes. The bike was running lean and we are only into the first fuel tank with it, but the wife noticed that it has less decel pop.
