Weird ignition problem
Old 07-16-2019, 07:55 PM
CJHD's Avatar
CJHD
CJHD is offline
Default Weird ignition problem
Hey all,
2000 sportster 1200XL owner here. The other day i went to start my bike, all lights turned on but when i hit the start button everything died. Bump started the bike and it ran fine for about 8 miles in which the tach started jumping and the bike started misfiring when the tach jumped. A day or so later the bike will not start again, battery is at 12.8 volts, but as soon as i turn the ignition on it drops to about 8. If i bump start the bike it drops to 3 and all the lights so crazy, but will recharge back to 12.8v if i let it sit. Anyone had any similar experiences with this? Ignition coil? Ive checked all fuses and wiggled the battery while checking the voltage and still at 12.8v. At points i can turn the ignition on and everything comes on fine, but as soon as i flip the switch to start the bike the battery drops to about 8v.
Old 07-16-2019, 08:51 PM
marcodarq's Avatar
marcodarq
marcodarq is offline
You need a new battery.
M
Old 07-16-2019, 11:23 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,258 Likes on 3,629 Posts
Or loose battery terminals.
Old 07-17-2019, 06:57 AM
CJHD's Avatar
CJHD
CJHD is offline
Thanks for the replys, im going to take the battery in for a load test today.
Old 07-17-2019, 07:12 AM
marcodarq's Avatar
marcodarq
That year range also had issues with the battery cables, make sure that the crimps are nice and tight.
M
Old 07-17-2019, 07:37 AM
CJHD's Avatar
CJHD
CJHD is offline
Thumbs up
Ill check those as well. Just kind of weird how sudden it all happened which made me think it first it was a loose connection. But even with a tender on the battery is fully charged and as soon as the ignition is switched to on it drops to 8-10v. Those 2 seem like the most likely culprit. I tested the stator maybe 2 weeks ago as well and it was charging the battery pretty well, not sure if they usually fail out right or if its a steady decline in performance. New voltage regulator a month ago. Hopefully I just got unlucky with a battery.
Old 07-17-2019, 04:24 PM
Stephen Thomas Diggs's Avatar
Stephen Thomas Diggs is offline
Stage III
Did your issue get fixed? I'm having a similar problem with my 04 electra glide cvo. I haven't tried bump starting it but my battery is showing fine.
Old 07-18-2019, 11:09 AM
CJHD's Avatar
CJHD
CJHD is offline
Hey! yeah finally running normal. I tried my buddies battery and it fired right up and runs fine now. My old battery looked fine and i was getting 12.8 on my multimeter but i guess under load it just craps out (relatively new battery too).
Max Headflow (07-18-2019)
99sporty99
06-25-2019 06:40 AM
bjc
05-23-2017 02:28 PM
mrbig381
03-25-2012 05:00 PM
essentialcycle
07-16-2010 06:52 PM
clove07
Shovelhead
17
08-17-2009 11:41 PM
Quick Reply: Weird ignition problem
