Baz
Old May 22, 2017 | 01:35 PM
bjc's Avatar
bjc
Stage II
Default Baz
fitted brand new battery after old one died, when i turn on ignition battery goes down to 7.5 volts and if i try to start engine voltage drops to 1.5 volts, battery is fully charged.
Old May 23, 2017 | 08:35 AM
archergodwin's Avatar
archergodwin
Find whatever is pulling all that juice... sounds like you have a meter... start pulling different fuses till you find the circuit that is dropping your voltage, then start going through that circuit.
Sounds like maybe a shorted starter solenoid?... but the 7.5 for just turning on the ignition is not right.. .you've got a couple of things out of whack there.
Old May 23, 2017 | 01:55 PM
Nickd2689's Avatar
Nickd2689
Your ignition shouldn't drop that low without load. Test the battery before anything. You could have one or more shorted cells. That's what I would think would be most likely. Wouldn't hurt to test amperage draw from the battery, then turn the ignition on. If it's high, you can pull fuses/disconnect components until it drops low. Let us know
Old May 23, 2017 | 01:58 PM
Max Headflow's Avatar
Max Headflow
Sounds like the new battery ain't so new.. If getting 7.5 volts at the battery with the ignition on, you should see smoke somewhere..
Old May 23, 2017 | 02:16 PM
Nickd2689's Avatar
Nickd2689
im wondering if it's a new battery or a new-used battery. When I see voltages like that at work (Chrysler tech) it's normally a shorted cell.
Old May 23, 2017 | 02:28 PM
Max Headflow
Could be that or simply a new AGM battery placed that had been placed on a dumb old style charger for too long. It simply dried out...
Jody858
Jan 12, 2025 11:36 AM
99sporty99
Jun 25, 2019 06:40 AM
essentialcycle
Jul 16, 2010 06:52 PM
clove07
Shovelhead
17
Aug 17, 2009 11:41 PM
nycgroov
Nov 20, 2005 07:33 PM
