Harley Race Tunner
Old Aug 27, 2024 | 03:01 PM
FLHXIGlide's Avatar
FLHXIGlide
Default Harley Race Tunner
Hey guys, Hoping you can give some advice. HI have a 06 FLHXI w/ Rineharts and Air Cleaner Kit with a Harley EFI Race Tuner Kit part#32107-01E.I'm planning some upgrades including cams and will be using a Power Vision PV-1B tuner as recommended by Dyno Tune. I've been told first thing I must do is remove the Race Tuner tune and revert the ECM back to the stock tune. I have all the parts from the purchase CD, cabling, and the race tuner. First off the CD states PC running Windows XP, 2000,ME, or NT4.0. Will this software work with Windows 10 or 11 or do i have to get newer software? Also can anyone give me some pointers on how to proceed? I'm very mechanical inclined and computer literate but never messed with Harley tuning. Any help and assistance would be greatly appreciated Thanks.
FLHXIGlide.
Old Aug 27, 2024 | 07:20 PM
Ed Ramberger's Avatar
Ed Ramberger
Not really sure you have to revert. I have used PowerVision over Harley's race tuner flashes. You may want to double check that.
In reality it's a moot point because you can't reload the Factory tune with the race tuner. Closest would be a stage 1. The dealer would have to flash it back to factory.
Old Aug 27, 2024 | 08:56 PM
Rusty Springs's Avatar
Rusty Springs
My 2015 was tuned with a SE race tuner. The dyno guy didn't have any problem flashing it with Power Vision.
Old Aug 28, 2024 | 12:11 AM
NorthWestern's Avatar
NorthWestern
This right here. I had 2 of them done with the SE tuner, and a PV2 (or a 1B) was able to burn right over the file that was in the ECM
Old Aug 31, 2024 | 01:30 PM
FLHXIGlide's Avatar
FLHXIGlide
Thanks guys, I'm going to call Dyno Tune Wednesday. I was told by 1 HD Dealer that I have all the cables and other stuff that I can do my self or bring it in and they could re flash. Also they said it must be remove and returned to stock before continuing. Also I was told the stock program should have been saved. Another HD Dealer said I can't do anything and they would revert back to stock for $250? One of them is lying. Thank you.
Old Aug 31, 2024 | 10:08 PM
Ed Ramberger
Harley does not charge for the oem tune - at least they did not in the past. The tune is available to the dealer at no charge. The dealer may charge labor which realistically takes about 15 minutes to prep, hook up, flash - but most will charge .5 to 1 hour.
I flashed over my Screamin Eagle tune with PowerVision. You can literally flash the ecm with either - back and forth.
Old Sep 1, 2024 | 09:22 AM
paulmedford's Avatar
paulmedford
Only the TTS or original black box race tuner as far as I know, you have to revert to stock map. (And TTS website, has the map to revert to stock with their tuner) You can, as others correctly stated, flash the pv tune onto your ecm right now without reverting to stock. So tell whoever you go by to tune, that you can take your pv and play it in and start tuning.
drakenkade
May 24, 2023 12:16 PM
95ci springer
2014-2024 Touring Models
Mar 4, 2015 08:23 AM
pillows
Oct 17, 2011 07:58 AM
cowboy Harry
Oct 17, 2010 09:13 PM
2wheeltom77
Feb 7, 2010 01:37 PM
