O2 clearance from the heads with thunder max
I am thinking of putting a thunder max in my bike while I am doing this I would like to change my head pips to true duel I read that with some manufactures your might have trouble ( clearance problems) with the o2 sensor touching the heads. Has any body install a thunder max with auto tune and change to true duels if so what brand of head pipes did you use and did you have trouble with the clearance from the new o2 sensor?
RE: O2 clearance from the heads with thunder max
Install was easy. I only have about 150 miles on it but so far the bike starts and runs MUCH better than the Power Commander and the V&H Fuelpak I had on it before! I am experiencing a little decel popping but have noticed it going away a little. I have been told by a member on this forum that Zippers will be releasing something soon for the ThunderMax that will take care of that.
I have the V&H Big Shot True duals and Thundermax setup on my '07 RKC. While the rear o2 sensor is close, it has posed no probs in 1500 miles and runs GREAT! Using Zippers Airfilter setup as well. The angle of the pic makes it look even closer than it actually is. Since there is no vibration or movement in relation to pipe/engine, there are no chafe issues. Of course YMMV
[IMG]local://upfiles/26245/E7BB6E2CE83145B8A8A95D83DE728C6A.jpg[/IMG]
