engine code
Old Jan 28, 2008 | 01:27 AM
fiddledicksr's Avatar
fiddledicksr
Default engine code
i HAVE A 2004 EG and it has a engine trouble code set, my 1999 manual told me how to read them and what they support. My new manual doesnt tell me how to read them or what they are for. Does any one know where I can find this info.
Old Jan 28, 2008 | 09:35 AM
fxrp's Avatar
fxrp
Default RE: engine code
Attached is a pdf file of a tri-fold flier I put together in 2004 which will tell you how to retrieve codes and includes a list of codes. The forum won't accept pdf files so download the file, remove the txt extension and then open it with acrobat reader.
Old Feb 1, 2008 | 11:24 AM
raylikesbeer's Avatar
raylikesbeer
My 02 has separate manual for ecm related electronics.
Old Feb 2, 2008 | 08:14 AM
Heathen's Avatar
Heathen
If you cant find the code try checking the EFI sensor plugs,a common problem is a broken wire just behind the plug.
Old Feb 16, 2008 | 12:24 PM
BeenThere's Avatar
BeenThere
Once again a forum member comes through with just what I need. My check engine light started coming on occasionally. Five minutes of looking on the forum and I find out how to display, decode and delete the error code - all in a nice brochure! Thanks.
gabulldog
Apr 30, 2010 07:23 PM
Roadglide3
Jan 5, 2008 08:38 AM
Jazz56
EVO
15
Sep 24, 2007 07:36 AM
daboys53119
May 19, 2006 07:16 AM
oldfartjc
Apr 26, 2006 08:32 PM
