engine light , ecm code
Old Feb 20, 2008 | 07:06 PM
patsac's Avatar
patsac
Default engine light , ecm code
07 flh....at times the engine light comes on.... only in 6th gear...when it does all i have to do is give it some gas or back of a bit and the light goes off.
so i believe that it was a historic code..so i cleared it....then across the odometer..i read "pn 34455-076...hmmmm...take it for a good ride ran great and check it again..it tells me there are no codes....which is a good thing but...there it is again "pn 34455-076" thinkin pn= part number i get in h/d s web site and type it in....no such part !!
any ideas?
Old Feb 20, 2008 | 08:05 PM
prc1333's Avatar
prc1333
Default RE: engine light , ecm code
Is the gas cap on tight? One click after tight.
Old Feb 20, 2008 | 08:32 PM
6flhxi's Avatar
6flhxi
the p/n you are seeing in the odo screen is simply the OE part number for your speedo 34455-07B (which has nothing to do w/ the historic code). If the engine light comes on and goes off, you're correct...it's historic and it should be there for you to retrieve. Are you sure your checking the codes correctly? The run/stop switch must be set to run. Hold the trip button in and turn the ign switch to on and it should read "DIAG". Scroll through each of the modes to check for the codes...pay attention when in "P"owertrain menu as that's likely where the code is residing. Otherwise you should still be under warranty and the dealer should at least be able to tell you what the code isat no cost to you.
Kyle C Kirk
Nov 9, 2015 02:13 PM
AdrianVall
Sep 6, 2011 04:44 PM
SE120RG
Jul 20, 2009 08:00 AM
Jock
Apr 27, 2008 01:20 AM
KeithB
Exhaust System Topics
17
Nov 2, 2006 09:48 PM
