TFI settings
TFI settings
have a tfi on my 06 nightrain using the settings that came with it 3-3-4-4 its running way to rich just checked mileage on last tank and came in at 25 mpg and pipes extremely sooty
have just changed settings to 2.5-2.5-4-4 any body else offer some setting advice seems to run fine with theses setting but will have to recheck mpg
oh yeah have stage 1 download hypercharger and santee shooters
RE: TFI settings
Also check out the doebeck performance site www.techlusion.com they have a message board that will help you fine tune it. The TFI is a nice product, I had it on two bikes. I am now running the PCIII due to more adjustability. With the TFI it is a lot of trial and error. just carry a small screw driver with you and make adjustments.
To set the #1 pot turn it off to the number 1 position. Start your bike and turn the throttle to 1800 to 2000 rpm and hold it there. While keeping it at the specific idle turn the #1 pot until you hear a change in the idle. (it will run rough, smooth out, then rough again) once you get to the second rough spot turn it back 1/4 turn and that should be a pretty good setting. When I was running mine I actually had it set at 3.15/3/4/3.8
On the 4th Pot I had it come in just before 4000 rpm for that top end rush.
As said before it is trial and error.
Good Luck.
Mike
Good Luck.
Mike
RE: TFI settings
The suggested settings are a bit rich for most bikes. Set the green pot as suggested above at 1800 rpm's and find the sweet spot where it runs best, back this off to the low (lean) side just a bit. The accel pump #2 pot will kick the crap out of the mileage but it works well. It to can be backed off somewhat for mileage. The #3 pot, is the top end and can be set lower also as the fuel maps are usually rich in the upper ends more so than the lower ends and need less help there. The #4 pot (crossover) if you do a lot of high speed driving can be raised 1/2 number or so to keep the fuel off till a higher RPM
With the settings you are using it appears as you have the intake and exhaust also the download. You can back off on your settings and get good MPG with the TFI
I have mine set at 1--2 1/2-- 4 1/2 -- 4 down from the recommended 3-4-6-4 on a 95 inch with 203 cams and stage 2 download with intake too and I have gotten 47.7 MPG on the road and it runs real good. It's a matter trial and error.
Correct on pots 1 - 3. On the #4 going higher is off not lower. You turn off the crossover by going higher and do not let #3 cut in where ever it is set by doing this. If you care to check the #3 pot turn the #4 pot all the way up and you can see the adjustment the #3 pot makes by turning it while the engine is running.
Techlusion also has some great tech support, here's more info in the DIY https://www.hdforums.com/m_67610/tm.htm
so if 1 is the off position anything higher must be adding fuel is this right
RE: TFI settings
Just in case anyone needs some other variables. I just had 203 cams installed. My settings are with this configuration...
VH Big Radius / Thunder monster Baffles
SE Aircleaner kit with K&N replacement with Screaming Eagle cover.
DFO Settings... 1.5--3.0--3.0--4.0.
Bike runs great now. Don't have mileage just yet. Since I made the moves recently, need to get that info.
