'06 EFI/ECM service bulletin
Old 02-22-2006, 11:36 AM
xkvator's Avatar
xkvator
xkvator is offline
Default '06 EFI/ECM service bulletin
here is the service bulletin for the fix on '06's
http://mysite.wanadoo-members.co.uk/hhlair1/M1185.pdf
Old 02-22-2006, 11:46 AM
XGlide's Avatar
XGlide
XGlide is offline
Default RE: '06 EFI/ECM service bulletin
Didn't know there was a problem. Thanks
Old 02-22-2006, 11:54 AM
CHEYENNE's Avatar
CHEYENNE
CHEYENNE is offline
Yea with cold starts. I just figured it was mine. I never read anything on here about it happening to anyone else. I'v almost dumped mine a few times from it wanting to die while turning out of my driveway. I actually have had to ride the gas and feather the clutch so it wouldn't happen.
Thanks
Old 02-22-2006, 02:19 PM
Dan B's Avatar
Dan B
Dan B is offline
Does this only influence cold starts or are there any other symptoms that can be related to this?
What's with the remapping? Does it enrich the cranking fuel and varm up enrichment tables?
//Dan B
Old 02-22-2006, 03:40 PM
Rhubarb's Avatar
Rhubarb
Rhubarb is offline
Anyone have a performance increase from these injectors?
Would it be worth doing to a bike without problems?
Old 02-22-2006, 07:51 PM
CHEYENNE's Avatar
CHEYENNE
CHEYENNE is offline
I would think there would be a little performance upgrade do to more fuel being used seeing as most bikes are running lean.
Old 02-23-2006, 01:20 PM
xkvator's Avatar
xkvator
xkvator is offline
Mine runs smoother...especially in the 1500-1800 rpm range - that's where it stumbled starting out in very hot weather...and it runs much cooler.
Old 02-23-2006, 11:27 PM
oldfooter's Avatar
oldfooter
oldfooter is offline
Sent this to my dealer as my springer has this problem he hadn't seen it. He ordered new injectors for mine will install. Now do you know are these injectors the same as far as amount of fuel delivery as orig. Will this solve any of the lean problems. Thanks
Old 02-24-2006, 10:32 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
The dispursement angle is different and the spray openings are double from 3 to 6 along with a remap of the ECM to change the fuel mapping so I would say that it will increase fuel delivery somewhat and eliminate the lean mapping to a degree but not as good as a fuel enrichment device would.
Old 02-26-2006, 01:35 PM
Roadie 49's Avatar
Roadie 49
Roadie 49 is offline
My 06 RK is now in the shop having this done.
I'll do stage one with SERT tuned on a dyno next
month. Be interesting to see how it turns out.
Quick Reply: '06 EFI/ECM service bulletin
