Turn Signal Blues....
Started like this......
I noticed about a month ago that shortly after I had started my bike and headed out that the speedometer had no power.
After a second or two of noticing... it came alive.
After three or four more such instances, I became worried... and then it seems my turn signals are affected now as well. ( Specificaly the Right. )
At first they would just cut out, or not start in the first place.... and sometimes the activating of one would kill the Speed-O.
Now the Right will not start at all, and still kills the speed-o every once in awhile.....
But if I activate the left, pressing the Right WILL stop the Left as is normal.
Was that I could "Trick" the right into working.... by activating the Left first, and then pressing the Right Twice... but not anymore.
All clues I have gleamed thus far steer me towards the "Module", or a bare/broken wire.... but what a choice !!!!
Any advice.......
Thanks....
Budds................
Any advice.......
Thanks....
RE: Turn Signal Blues....
I would first check the connectors for the leads in the system. There might be a loose connection causing high impedence in the system. Also check all of the ground points in the system for good continuity (use a ohm meter and check between the wire and a known good ground on the engine) to make sure that there isn't resistance between the bolt and the connector. I lean towards a poor ground because there are more that one system affected. If all checks out then go for the module.
If your going to go somewhere, have fun getting there.
ORIGINAL: 12custom
I had some what of the same problem turn out to be my ing. switch They would work and them not work speedometer light would not light
Good Shot !
It appears the switch is at least partly responsible, if not the whole problem.
Thanks Guys.
Budds....................
Long lonesome highwayman
Electrical/Lighting/Alarm
21
04-08-2019 05:49 PM
Daehawc
06-15-2009 06:57 AM
