Calibration Number for stock 08 Dyna FXD
Old 08-30-2008, 03:00 PM
BlockHead96's Avatar
BlockHead96
BlockHead96 is offline
Default Calibration Number for stock 08 Dyna FXD
Anyone know OEM Calibration # for the Dyna, 08 FXDL? I just had an Upgraded Stock calibration done this morning, number 32899-07F/DT. If that is the upgraded number, what is the original number? The surge is back, where as it was basically gone with the heat management program. Is it time to dump this thing with only 1700 mi on the clock??
I'm starting to get a bad taste in my mouth with HD and the stealer, they choose not to give you any info as to what they will do and what it does...
Old 08-30-2008, 05:49 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Shovelhead Bob is offline
Search Results: 3 Applicable Calibration(s)
Digital Tech Part Nbr: 32899-07E/DT
Calibration ID: 32899-07E
Description: STOCK OE
Street Legal for: 49S,Calif.
Race Only for:
Restricted Power: Unrestricted - (Full Power)
Req'd Configuration:
Model Year: 2007, 2008
Platform: Dyna, Softail
Model: FXD, FXDB, FXDC, FXDF, FXDL, FXDWG, FLSTC, FLSTF, FLSTN, FLSTSB, FXCW, FXCWC, FXST, FXSTB, FXSTC, FXSTD, FLSTC (SHRINE), FLSTF (SHRINE)
Exhaust System: Original Equipment (Legal)
ECM/ICM: 32498-05,32498-05A,32534-05,32534-05A,32534-05B,32852-06,32852-07,32534-05C,32852-08,32852-08A
Cylinder Heads: Original Equipment
Engine Displacement (cc): 1580
Fuel Injectors: 06-09 Twin Cam 25 deg Injector (27709-06 / 06A)
Air Cleaner: Original Equipment
Throttle Body/Induction
Module: Original Equipment
Cam Shaft: Original Equipment
Pistons: Original Equipment
O2 Sensor: Original Equipment
Description: STOCK CAL - STREET PERFORMANCE EXHAUST
Race Only for:
Exhaust System: H-D Slip-On & SE Street Performance (Legal)
Race Only for:
Search Results: 1 Applicable Calibration(s)
Digital Tech Part Nbr: 32899-07F/DT
Calibration ID: 32899-07F
Race Only for:
Old 08-30-2008, 06:29 PM
BlockHead96
Outrageous, where did you find that??? Mine is letter designation F, So It must be an upgraded program. Now, I wonder what it has changed?? I was having issues with Ping, but haven't yet really ridden the bike today to see if it is still there.
Thanks for that great info!!!
To bad it doesn't tell you what the differences are between programs.
Old 09-20-2008, 06:53 PM
dtseed's Avatar
dtseed
dtseed is offline
Stage I
I had my 08 FXSTC calibrated with the 32899-07F this week and it got rid of the valve pinging. What a relief!!
Old 10-12-2017, 11:36 AM
rgppgr's Avatar
rgppgr
rgppgr is offline
5th Gear
Question same EFI problem on 05 Night Train
Can you or anyone tell me what 32899-05c means? A local says this is what's in the ECM. Harley Paymesome won't tell me anything else. Well one stealer did. He said it was a part number but not theirs. Any help as I want to start playing with it. I couldn't believe the above info from Shovelhead Bob. I wonder how he can come up with all that and the man behind the counter can play so dumb? Well maybe he isn't playing!
Old 10-12-2017, 04:03 PM
jbarr1's Avatar
jbarr1
jbarr1 is offline
32899-05c is a stock calibration for an 05 Softail.
Old 10-12-2017, 04:21 PM
rgppgr's Avatar
rgppgr
rgppgr is offline
5th Gear
Thanks jbarr1. Now to go play. The bike has SE II exhaust only. After I cleaned the air filter (dirty) and adjusted the clutch it runs nice. People tell me it will run better and be better for the bike if I Stage 1 the AC and add a little tune.
Old 10-12-2017, 08:26 PM
rgppgr's Avatar
rgppgr
rgppgr is offline
5th Gear
You guys are awesome. I don't know where you come up with this stuff but I'm so glad you do. Not one no- dealer in the KC metro area could give me that info. Gails Harley was the worst.
Ironworker69
Milwaukee Eight (M8)
04-18-2019 07:09 AM
Andy-Deuce
02-19-2014 07:46 PM
01Byte
Touring Parts
06-19-2012 07:08 PM
rhinoevans
01-14-2007 02:53 AM
CHASE
09-24-2006 07:41 PM
Quick Reply: Calibration Number for stock 08 Dyna FXD
