Left turn signal
Old 09-25-2008, 02:59 AM
batmanofasheville's Avatar
batmanofasheville
batmanofasheville is offline
6th Gear
Default Left turn signal
Ok here in lays the problem. I have a 2000 RoadKing and the left turn signal keeps messing up. If I am stopped, the signal works fine. It is when I am riding down the road that it seems to act up the most. When I turn the signal on, like for when I am going to change lanes, it stays on (not blinking). However if when I am riding down the road and I slow down enough to where I am going to make a turn, it will work. I have no problems with the right turn signal what so ever. Any ideas of what the problem is and how to fix it?
Old 09-25-2008, 09:40 AM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
Start with the easy stuff first. Check the bulbs front and back. They may appear Ok but the filament is broken.
Old 09-30-2008, 03:24 AM
batmanofasheville
6th Gear
Yes sir did that and all is well. Still doing the same thing.
Old 09-30-2008, 03:35 AM
hogdoctor's Avatar
hogdoctor
hogdoctor is offline
your turn signal module has a feature where if you do blow a bulb, it will not flash, so you know there is a problem. If you have a failing ground or a poor connection somewhere in the circuit that is reducing current flow, it can also not flash. It sounds like you're right on the threshold of that current setpoint.
Check your bulbs... if you're running 1156 and 1157 bulbs, this can cause this problem. They do not draw as much current at the oem bulb from harley. Try to find a slightly higher wattage bulb.
Hogdoctor
Old 10-08-2008, 10:11 PM
batmanofasheville
6th Gear
Ok thanks, I know I put an 1157 in after ther bulb blew. So I will check it and let you know if that did the trick.
Geo rage
Electrical/Lighting/Alarm
11
03-24-2013 02:21 PM
W1ldC4t
11-27-2012 05:08 PM
unclerogi
06-16-2012 09:13 PM
stoneman
06-19-2011 09:50 PM
gilyoyo
11-01-2010 03:07 AM
Quick Reply: Left turn signal
