Turn signal problems
Old Mar 21, 2013 | 07:21 PM
Geo rage's Avatar
Geo rage
6th Gear
Default Turn signal problems
Ok, 93 Sportster left turn signal works fine. When I press the right side turn signal it illuminates but does not blink. I have changed all of the bulbs. I have checked the wiring and everythings seems to be secure. What makes the bulb blink and is there one for each side? thanks!
Old Mar 21, 2013 | 07:23 PM
davidwruth's Avatar
davidwruth
Have to ask but is the bulb you replaced good. Did you try swapping the bulbs? Sorry but I have seen bad ones out of the package
Old Mar 21, 2013 | 07:26 PM
RANGER73's Avatar
RANGER73
+1 on new bulbs being bad. Also make sure you
1. installed the correct bulb
2. installed it correctly.
After that It could be the turn signal module.
Old Mar 21, 2013 | 07:27 PM
LeFat1's Avatar
LeFat1
replace signal module with known good one
Old Mar 21, 2013 | 07:31 PM
Geo rage's Avatar
Geo rage
6th Gear
That's cool. I just went to double check and yeah the bulbs work fine on the other side.
Old Mar 21, 2013 | 07:32 PM
Geo rage's Avatar
Geo rage
6th Gear
Where is the the turn signal module?
Old Mar 21, 2013 | 07:39 PM
Geo rage's Avatar
Geo rage
6th Gear
aahh a new twist when I push both turn signals(emergency lights) the flash like they are supposed to!
Old Mar 21, 2013 | 07:40 PM
LeFat1's Avatar
LeFat1
a black box that functions the signal parameters i had probs with signals on a 1990 FL and no one knew the problem, so i borrowed a good module from another bike and that fixed it
Old Mar 21, 2013 | 07:43 PM
Geo rage's Avatar
Geo rage
6th Gear
Thanks Le I think your right. I'll try that tomorrow. Thanks everyone
Old Mar 21, 2013 | 07:48 PM
LeFat1's Avatar
LeFat1
ur welcome, hope that fixes it..i was a cert HD tech in my past life
