Going to install Xied - question
Ordering Xied for my 2007 Road Glide - all stock
I think I've found the 02 sensors - one I think is located behind and left of oil fill/dipstick. The other is attached to brace on the frame above close to the oil filter. Does seem like the correct locations?
Any tricks to be aware of(I'm not real handy)?
Thanks for the help.
With a couple wire ties handy, cut the originals, carefully disconnect the connectors (about 4 or 5 inches back from the O2 sensor), then add Xied's and reconnect. Replace wire ties being careful to route wires away from pipes.
Good luck!
Good luck!
