Dyno Results on a 06 With VH Pipes andFuelPak etc...
Old 07-27-2006, 09:07 PM
jaspin's Avatar
jaspin
jaspin is offline
Default RE: Dyno Results on a 06 With VH Pipes andFuelPak etc...
Well I checked my settings on the fuel pack and they were correct. I also checked mode 20 and 21 which also were correct. Any other idea's on why I would be getting popping on decel?
Old 07-27-2006, 11:01 PM
jrudicel's Avatar
jrudicel
jrudicel is offline
Not a clue. Mine ran fine with no popping etc...just showed a little lean on the dyno. I would definately call VH and talk with Adam in FuelPak tech as he is suppoesed to be the man out there. Maybe they can tell you to try a different program, one thats a little richer. Sorry I couldnt help. you may have a bad fuelpak which in that case, you would need it replaced by them anyways. Keep us posted as to what you find out!
Old 07-27-2006, 11:49 PM
jaspin's Avatar
jaspin
jaspin is offline
I will keep you posted. Thanks again!
Old 07-28-2006, 12:40 AM
grunt0311vn's Avatar
grunt0311vn
grunt0311vn is offline
I've got a 2006 Deuce with a simular set-up. Big Shot Staggard's with quiet baffles. Sceamin' Eagle A/C, V&H Fuel Pak and stock download. Had mine dyno'd also and came out with about 72.5 HP and 75 lb. of torque, the A/F was roughly 15 at low RPM and went down to just a shade under 14 at higher RPM with no spikes like yours. I was told the same thing being a little lean.
I was looking at the map for regular baffles, which is way different and thinking if I change to that map it might richen it up a little. Have to check with V&H to see what they say.
Old 04-01-2013, 03:07 PM
jojo2dog's Avatar
jojo2dog
jojo2dog is offline
put on a set of xieds you will see a lower afr and a decent improvement sorry no o2 sensors xieds won"t work
Rollerskates
07-15-2011 01:30 AM
mynzbtr1
09-03-2008 10:25 PM
shimmon
05-05-2008 05:38 PM
Bluedog20
04-12-2008 04:07 PM
the_icemAN
05-17-2007 02:13 AM
Quick Reply: Dyno Results on a 06 With VH Pipes andFuelPak etc...
