MasterTune TTS wont install
According to the TTS website you should be good to go.
I would call TTS if you have the disk and the software won't load onto your computer. Must be a setting somewhere preventing it.
The TTS MasterTune software is compatible with Windows 98 through Windows 7. Both 32- and 64-bit versions of these operating systems are supported.
Which version of windoze 7? I have a ACER 1810T netbook with windoze 7 home premium and TTS installed and worked fine (used a usb CD drive). Not sure about windoze starter, however. I tried to contact TTS but did not get an answer, but it got overtaken by events as the netbook had the more featured windoze 7..
Not sure if this will help, but widows 7 needs a new driver. I found this from a different site.
http://www.ftdichip.com/Drivers/VCP.htm
Look on the right side of the page under "Comments" and find where it says "setup executable" and "click" on it.
Not having the driver would not cause the software to fail installation. It just won't connect to the bike. (don't ask me how I know that) If you follow all the directions, one of the first things you are suppose to do is load the USB driver. The load driver install should pull down the right driver.
SSTuner
03-12-2014 06:24 AM
