VCI Update Issues.
Location: Back in the Good Ole USA. South Carolina to be exact.
VCI Update Issues.
I recently upgraded my SEPST software to the latest version and this included a flash update to the VCI. I’ve been tweaking the timing advance tables of my calibration so I put the VCI on the bike and activated it for data recording.
I pulled out onto the street and immediately noticed that both the tach and speedometer were at zero regardless of engine or vehicle speed. I went ahead and rode a bit, but I had wanted to get data at specific speeds and rpms and throttle positions, so this ability was compromised.
I reflashed my calibration, and tried a number of other things, but the speedometer and tach worked fine in every case until I attached the VCI and activated it for data recording. Once the VCI was activated, it would record data fine but the tach and speedometer would no longer function.
Now, my bike is an 08 Fat Bob. I use a tach when I ride but the bike didn’t come with a tach so back when I got the bike I purchased the Combination Speedometer/Tachometer - Spun Aluminum Face, Part No. 74718-08, which has always worked fine. So I figure since the updated VCI just doesn’t like the Speedo/Tach.
I contacted my dealer and spoke to the tech that runs the dyno and is most familiar with the SEPST. He hadn’t heard of this problem and hadn’t seen any tech bulletins about it. I contacted HD corporate and they just referred me back to my dealer. So I Googled SPX and found a number to call. The problem was that the automated attendant just told me to enter the extension of the person I wished to speak with. I had no idea, but it gave me to option to search by last name so I entered the keys for smith on my phone and I got four hits. All went to voicemail except for the last one. I explained the problem and Mr. Smith transferred me to the right guy. I again explained the problem and this guy was extremely concerned and helpful. The next day I received a email saying that they had been able to recreate the problem with the Tach/Speedo. The next week I received a fix which I installed and it did indeed fix the problem. I was also informed that there would be an update in February.
The willingness to help, and the level of support and knowledge at SPX was very good. HD?? Not so much.
There are two forms of update. The software update and the VCI update.
The software update comes first.
With the VCI attached you then update the VCI.
Did you update the VCI this way?
also... are you running stock plug wires?
There is a reason I asked.... some that use the SEPro don't know about the VCI update and it is a separate procedure.
Next, I had the same issue with the tach/speedo. Had to go back to the stock plug wires. Seems the aftermarket interfered with both the tach/speedo and the radio operation of all things. Once replaced, everything worked fine.
Yes, I had heard some time ago that aftermarket plug wires can compromise the ION sensing for knock detect.
In my case it was definately due to the accessory Tach/Speedo being clobbered by the firmware update. Without the VCI everything worked perfectly. Attach the VCI and activate it and the Tach/Speedo die. SPX recreated this issue using my configuration and developed a fix. They were kind enough to send me a pre release. The official release of the fix will be included in an update released in February.
Great info, but what type of fix was it. A software patch for the tuner or a some type of patch for the bike? I did not realize SPX was "support" for the super tuner or even would talk to a non-dealership person. What number did you call.
SPX does not do end user support, HD requires all support go through the dealer network. I just kinda did an end run and got lucky.
Just installed SEPST, ran the updated to my PC when I loaded the software, then when I connected the VCI to my bike, it told me to wait for a VCI update. Here are the versions I have:
Description
Version
Screamin' Eagle Pro Super Tuner Software Version
4.003.0002
Vehicle Communication Interface Software Version
289
Just a suggestion but...
If you guys with the SEPro would start a thread about the SEPro and it's functions, abilities and inabilities... Maybe toss in "how to smarttune". I could easily make it a sticky much like the TTS has at the top of this forum.
I don't know why this hasn't been discussed before but we could make it happen. Anyone want to volunteer and start a SEPro discussion thread?
