Power Vision Information Thread
  #9161
Old 03-21-2019, 05:40 PM
RayHD11's Avatar
RayHD11
RayHD11 is offline
Voids warranty on the power train...guess that makes the decision a lot easier.
  #9162
Old 03-31-2019, 09:48 AM
brianfl67's Avatar
brianfl67
brianfl67 is offline
Have a question for you guys I have a 2017 street glide cvo with Khrome werks 2 into 2 full exhaust. I have done the 3 auto tunes and have noticed that my idle bounces around above 1100 rpm after bike is all warmed up. It sometimes hovers around 1500. Any ideas. Only does it intermittently. Thanks
  #9163
Old 04-01-2019, 02:40 PM
david barnby's Avatar
david barnby
david barnby is offline
Hi Brian- what are you using to Autotune? The PV alone or a Dyno jet module (Target Tune) wideband kit?
What Tune is your starting point? The stock Tune or have you flashed a different tune?
Let us know so we can try and help.
If if you made the induction and exhaust changes and are auto tuning to the stock tune in The ECM there could be all sorts of funnies.
  #9164
Old 04-02-2019, 01:18 AM
brianfl67's Avatar
brianfl67
I am using a tune sent with the power vision I don't have Target tune just a power vision.
  #9165
Old 04-02-2019, 01:25 AM
david barnby
Was the tune sent built for your bike model and the mods done to it?
Are you comfortable using WinPV to look at it?
Did you copy original tune into you PV so you can look at the differences in the tune?
  #9166
Old 04-02-2019, 04:30 AM
brianfl67's Avatar
brianfl67
Yes it was built for my bike not real good with the computer not really sure what I'm looking at when I get into the winpv.
  #9167
Old 04-02-2019, 04:31 AM
brianfl67's Avatar
brianfl67
I did back up my original tune to the computer is that what you're getting at
  #9168
Old 04-02-2019, 04:32 AM
brianfl67's Avatar
brianfl67
It looks like it's going to be warm enough today to ride a little bit going to try and do a couple more Auto-Tune anything special I should set up in the Auto-Tune
  #9169
Old 04-02-2019, 04:48 AM
david barnby
great Brian - if so the you should be able to email me both files so i can look at them
i would be looking for some of the switch settings etc as well as the chosen AFRs
if you are going out today then just make sure you don’t do rapid throttle changes, try and keep steady revs and load for as many cells as possible.
maybe also, once it is warmed up and the AT running, park up and get the cells filled around tick over revs.
you mentioned you have dual headers ? where are the stock sensors mounted?
  #9170
Old 04-02-2019, 05:44 AM
antlockyer's Avatar
antlockyer
antlockyer is offline
Hi All, I have a 2015 Dyna, witha redthunder 2 into 1, Fueling reaper 574 cams and 0.030 gaskets. I got a base map from DJ that matched the cams (was from a 2012 softail) and have done a bunch of autotunes since.
When I get into traffic the temps rise pretty quickly. We split lanes here but even still it's only first and second gear and on off power the whole time. I then go through a tunnel and I'm over 300f. At that point there is all sorts of spark knock events on both cylinders but only seen up to 4 degrees max (6 is the max setting).. I've seen knock events before this when I'm trying to move about in traffic and am below 2000rpm and ET of around 289f
Is there anything I can do to richen things up for the use case I have? The rest of the time when I'm jamming along the bike runs pretty cool and sems strong but is shocking in traffic.
Quick Reply: Power Vision Information Thread
