aftermarket front turn signals(3wire to 2wire)
Old 11-26-2011, 04:21 PM
ironmike666's Avatar
ironmike666
ironmike666 is offline
Default aftermarket front turn signals(3wire to 2wire)
what is the extra wire for? And is this the reason my signals will blink normally for a few seconds then blink fast?
Help
and how do I fix this?
Old 11-26-2011, 05:40 PM
ironmike666
So this takes me to my next question about the rear signals and the 4 wires that are located on them. both sets of lights that the harley shop ordered for me are only 2 wire hmmmmmm????
Old 11-26-2011, 05:43 PM
trozenhorse's Avatar
trozenhorse
trozenhorse is offline
something makes no sense, front should match front and so on, some after market ones require a load stabilizer to work properly. think badlands makes them
Old 11-26-2011, 06:46 PM
ironmike666
i took my stock signals apart. when i hook the black and blue up to battery, the light is bright. when i hook up the purple and black or purple and blue...the light comes on but not as bright. does this make any sense??
Old 11-26-2011, 08:05 PM
poppavein's Avatar
poppavein
poppavein is offline
The 3 wires are probably ground/running/turn.
Old 11-28-2011, 06:19 PM
CosmoKramer's Avatar
CosmoKramer
CosmoKramer is offline
Front turn signals have two functions.....running light and turn signal. To do this they have a dual filament bulb. So you have a blue wire running to the dim filament for the running light, a violet wire running to the bright filament for the turn signal and the 3rd wire is black which is ground.
Your lights are blinking fast because the turn signals you have on do not match the resistance (too low) and thus the amp draw from the turn signal module that your stock bike had. So it blinks fast which is an aid to tell the rider a bulb is burned out.
Stock harley rear turn signals are turn signals only....so it is a single filament bulb and has two wires running to them, black for ground and probably violet again for the turn signals.
I suggest if you are going to be working on your bike to purchase the factory service manual. It will have the wiring schematics in it which will describe the following:
black = ground
blue = running light
violet = turn signal
Dudepants
04-12-2018 11:03 AM
jumccaff
04-25-2013 05:25 AM
huskytamer
05-09-2012 02:30 PM
brndray
02-15-2008 11:48 PM
imboden
08-24-2006 11:34 PM
Quick Reply: aftermarket front turn signals(3wire to 2wire)
