Wiring turn signals:
Old Aug 24, 2006 | 03:03 AM
imboden's Avatar
imboden
Default Wiring turn signals:
I just asked this in the softy section, but I thought I'd ask you fine folks as well....
I bought these signals off of ebay, and I'm wonderin which wire is which. there are three....black/blue/purple with a black stripe...
I wanna wire them into my wifes 79 FXS, but I don't know which wire is hot and which is ground.....and why the third wire?
sorry in advance for the stupid questions
Old Aug 24, 2006 | 11:11 AM
gbm's Avatar
gbm
Default RE: Wiring turn signals:
Assuming these are dual element lights, the black is always the ground, one of the other wires is for a running light and the last is for the brake light or turn signal. Get some test leads with alligator clips and bench test it with a 12V battery. Maybe someone at a shop will let you look at a wiring diagram. I think that all models of a similar vintage are color coded the same.
Old Aug 24, 2006 | 12:48 PM
jkenosh's Avatar
jkenosh
yeap the third wire is a runnin light, must be front turn signals
Old Aug 24, 2006 | 02:44 PM
DGlide04's Avatar
DGlide04
You didn't say whether you bought them for front or rear turn signals, but the fronts are 3-wire, the rear 2 as the rear signals don't have the running lights on a stock HD. The front signals can be used on the rear of the bike which isn't a bad idea to add the running lights, but it will take a bit of additional wiring. Just asking.
Old Aug 24, 2006 | 04:24 PM
Bigbird's Avatar
Bigbird
A good way to see what wire is the running light and what one is the turn signal is to hook the blac wire to the black (neg) terminal on a battery charger then touch the other two wires to the red (pos) lead, alernate the two. The wire that makes the light brightest is the turn signal. The dull one will be the running light. Good Luck.
Old Aug 24, 2006 | 06:14 PM
imboden's Avatar
imboden
thanks for the help everybody, tremendous help. I did buy four signals, and I bought front ones for the whole bike so I could have runners on the back too. I just didn't know what wire was what. But now this:
so I bought a meter at napa and I've been testing things right off of the battery with some wires. this is what has happened so far:
ok edit...just deleted all that crap. I've got it figured so when I hook everything up, they turn signals just FLASH. Then when I push the button they turn OFF and the flasher makes a fast click noise that dosn't stop. What have I done wrong?
Old Aug 24, 2006 | 10:44 PM
DGlide04's Avatar
DGlide04
I'm not sure, but the continual fast flashing may indicate that there is a problem with one of the bulbs. If you're using the 3-wire signals on all 4 corners of the bike, make sure that you have the same dual filament bulbs in all of the signals. If one is mismatched, it could cause the problem. I think the dual filament bulbs are 1157, singles are 1156, or the other way around. Just make sure all of the bulbs match first.
Old Aug 24, 2006 | 11:34 PM
imboden's Avatar
imboden
thanks, they all do match. man this is SOOO frustrating, but now I got it ya know, I gotta figure it out....don't wanna take it to a shop
Nashv755
Electrical/Lighting/Alarm
Jul 18, 2017 09:43 AM
ironmike666
Nov 28, 2011 06:19 PM
lowrider610
Apr 25, 2010 11:24 AM
brndray
Feb 15, 2008 11:48 PM
Badbagger
Jan 16, 2008 08:41 AM
