Radio Blowing Fuses
Old Nov 3, 2012 | 10:47 AM
xk49's Avatar
xk49
Default Radio Blowing Fuses
I bought a used Radio Tech am/fm radio from a member on another forum. Before I installed it, I wanted to bench test it first. The first thing I do is check the in line fuse for the hot wire on the radio wire harness. It's blown. So, I go get a bunch(just in case) of replacement fuses and lo and behold I pop two more.
I'm attaching the black wire to negative terminal. The red wire and the orange/white wire to positive terminal. As soon as I connect the red and orange/white wire to the battery the fuse pops.
I don't think I'm doing anything wrong and what has me worried is the fuse was blown when I received the radio.
Am I not connecting the radio correctly? I know the orange/white is supposed to go to a switch wire, but for testing purposes I think I can go directly to the battery, right?
I have verified that there is no short in the three wires from the battery connections through the deutsch plug connection in the radio wiring harness.
Old Nov 4, 2012 | 07:09 AM
xk49's Avatar
xk49
I completely disassemble the entire unit isolating each component board. I then hooked each board and associated parts. in sequence starting at the radio wire harness. There were three primary boards and some misc compenents(ie. LCD display, push botton interface, relays). I just hooked each one in turn to the wire harness and using the multimeter checking for shorts, nothing obvious. I then disconnected everything again, hooked up the wire harness to a battery then reassembled each component in turn to see which one was going to pop the fuse, nothing?
Radio appears to work now. Didn't change the red,oragne/white, black battery connections. There might have been a poor connection on the circuit boards and I accidentally fixed it as I disassembled and reassembled the parts.
liscio42
Mar 17, 2018 12:16 PM
CVO-RK
Audio Systems
11
Apr 22, 2013 09:26 AM
jgcable
May 16, 2010 06:19 PM
dbuff
Apr 30, 2008 09:45 PM
rgrecco
Mar 27, 2008 05:24 PM
