07 SG Electrical
RE: 07 SG Electrical
chopper
I'm gonna have to go with the obvious and say you will have to take the fairing back off and check to see if a loose wire is obvious. If not, then check for the speaker connection at the base of the speaker, and then check the output wires on the back of the radio for each channel.
Lastly, make sure that the radio itself has the balance set in the middle.
