Electrical shock from handlebar
Hi, this one may sound crazy. My bike is a 2010 Softail Custom FXSTC. I have started getting static shocks from my left handlebar/clutch handle on a random basis. It doesn't happen until I have been riding for about 20 minutes, after that it is pretty frequent. It is not a really hard zap, just a medium static shock, but it sometimes makes me flinch when I am driving or causes me to loosen my grip.
I've been over the wiring a bit to look for a loose or broken connection but everything seems sound. The bike continues to run fine when this occurs, no misfiring, no loss of power, everything else seems fine.
Does anybody have any ideas or suggestions on what this could be ? Has anyone seen this fault before ? Any help or suggestion would be greatly appreciated.
What sort of clutch cable are you running ?
Check to make sure the clutch cable has not rubbed through the wires coming from the primary to the regulator. It is all in the same area and would be the only thing I can think of that would give you a jump as it is 50vac in that area and after that it is 12 volt.
joshEyeti
General Topics/Tech Tips
06-06-2015 05:18 PM
