Almost rode 2 miles...
I have a 2013 Deluxe. I've recently installed Samson fishtails and rode about 50 miles. Today was the first nice day since my last ride. I made it about two miles before the bike started bucking, engine revving irradically and it died. I figure maybe the exhaust loosened up. So i had some tools, snugged it all up. Bike wouldn't turn over. Let it sit a bit, tried starting it and eventually it fired up. Idle sounded ok so i put my helmet on and made a b line right for my home. About a half mile back it started to crap out again. I made it home (luckily). It threw a P0113 code. Does anyone have any clues or have had some similar issues? Thanks.
I check that connection this morning and it seemed fine… So I removed my seat and I wanted to see if the fuelpak had anything to do with it… So I turn my ignition on and the fuelpak did not turn on! So I removed the fuelpak and plug direct into the ECM and started and ran so I think the source is the fuelpak.
Glad you found the problem. When you post a question it is nice to have all the details such as fuelpak was added. If there were no fuelpak then the plug would be the first thing to look at then it would be the green connector in the handlebar coming off of the throttle sensor.
Stay safe out there.
thealien
05-23-2016 09:24 PM
