Ironhead A place to talk about Ironheads.
SS Super E tuning Trick
Old Jan 18, 2020 | 08:47 PM
nucklehead13's Avatar
nucklehead13
Default SS Super E tuning Trick
I got a SS Super E on my thousand cc iron-head and I got a printed manual for the carburetor. I just could never get the engine to run as good as the guy who put it on for me. I had to try things like hunt down the jets for my homes elevation, tried to adjust it right, put mini-baffles in the drag pipes. The other day I had to clean and lubricate the cables. While doing so I thought about routing them differently to be more like stock like the manual says. This time I made sure the throttle closed quickly with the front wheel pointed straight and left and right. Usually I take all the free play out of the cables and do not care if it closes quickly. This time I lucked out and read in the manual that in order to get the throttle to close quickly in every wheel position all you have to do is adjust a little more freepllay in the cable. Making the throttle snap shut just like the manual tells you to early on has made my bike run a lot better without any pops out the carburetor.
Old Jan 18, 2020 | 10:20 PM
IronMick's Avatar
IronMick
Amazing how very long and tedious the trail to success sometimes is
Old Jul 25, 2020 | 03:25 AM
doueitx's Avatar
doueitx
On the Earlier G carbs can I Plug the main jet Air Bleed and install my Main Air Bleed Outside on the back i,e, towards the Rear Wheel ON THE PLUG JUST ABOVE THE " G " THAT'S CAST IN THE CARB?
192.168.100.1 192.168.1.1 jpg to pdf
Frank D Cunha
Mar 22, 2018 06:33 AM
Archilochus
Jul 5, 2010 04:47 PM
besibela
Shovelhead
11
May 14, 2010 06:54 AM
Ky Windage
Jul 21, 2008 08:26 AM
Godfather86
May 15, 2007 01:17 PM
