Ironhead A place to talk about Ironheads.
Xlh breaker location
Old 08-26-2020, 07:57 AM
JonB's Avatar
JonB
JonB is offline
Default Xlh breaker location
Hi all,
just starting to put a friends xl together. Frame and motor match as 74xl, but the wiring and other bits are 75 (maybe it was a late 74?).
the wiring was original but in a mess so I’ve stripped the loom to clean and check resistances.
the 3 breakers were cable tied onto the top tube under the front of the seat, but there are 3 breaker holders riveted on the flat strap at the end of the top tube (presumably the original location?).
the odd thing is that the wiring from the headlamp bucket plug and from the ignition switch are very slightly too short (but have original ring crimps).
where would the breakers normally be?
as usual, no fusible wire, but I’ll fit a 30A breaker at the battery.
here’s the start
cklipp
Electrical/Lighting/Alarm
09-21-2018 06:40 PM
Superduper
EVO
11
08-15-2018 04:19 AM
hell hound
Shovelhead
08-12-2017 09:53 AM
DerrickC
Shovelhead
13
01-23-2015 01:03 PM
00keener
11-03-2014 04:54 PM
Quick Reply: Xlh breaker location
