Battery draining on 99 Sportster Sport
Old Nov 3, 2014 | 02:52 PM
00keener's Avatar
00keener
Stage II
Default Battery draining on 99 Sportster Sport
When hooking up the battery I'm getting a large spark, the relay is hot before turning the key on. Pretty sure it killed 2 new batteries. Its a friends bike and I'm trying to help get it running for the last few Michigan rides. I haven't found any physical damage to the harness to ground it out but it is defentally being grounded out.
Old Nov 3, 2014 | 03:34 PM
00keener's Avatar
00keener
Stage II
The problem is after the 30a breaker and before the ignition switch.
Old Nov 3, 2014 | 04:54 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If it were a short to ground, the 30 amp main breaker would trip.
To find out for sure if there is a short to ground in that wire, disconnect both ends, then check for continuity with an ohmmeter, one probe to the frame, the other to either end of the wire (remember, the wire must be disconnected at both ends).
If that wire is shorted to ground, you will need to trace the wire between the breaker and the switch and find the fault.
FTW101
Nov 4, 2018 08:02 PM
Superduper
EVO
11
Aug 15, 2018 04:19 AM
Ozark Joe
EVO
Feb 14, 2016 04:14 PM
jcallesano
Jun 1, 2014 08:39 PM
probatebob
Feb 7, 2012 06:40 PM
