Ironhead A place to talk about Ironheads.
1958 dry clutch
Old 11-02-2009, 08:43 AM
armybradarmy's Avatar
armybradarmy
armybradarmy is offline
Stage III
Default 1958 dry clutch
Hey guys im new, and dont know how to use this site very well. Here we go. I have a 1958 900cc iron sportster with a 4 speed dry clutch. I am now putting the clutch plates back in and am wondering how many and why there are 2 steel plates to go in first. The first plate in looks a bit different, but still it will go steel, steel, friction, steel, friction and so on. Is this correct, if it is there will be a total of 15 plates. Thanks. Brad in Tavistock
Old 11-02-2009, 12:24 PM
piniongear's Avatar
piniongear
piniongear is offline
The first plate to go in is a steel plate.
This plate is called the 'backing plate.'
The second plate to go in is a steel plate. This is called a 'driven plate.'
The third plate to go in is a fiber faced plate. This plate is called a 'friction drive plate.'
The following plate is another steel (driven) plate. This pattern alternates until all the plates are installed.
The last plate to go in will be a friction drive plate.
There are a total of 7 steel driven plates and 7 friction drive plates, along with the single steel backing plate, which makes a total of 15 plates.
After all the plates are installed, you then put the clutch release plate with the 6 holes for the spring cup retainers in place and insert the cups and springs, followed by the nuts.
I can post a pic of the clutch parts if you need one.
pg
Old 11-02-2009, 09:53 PM
IronMick's Avatar
IronMick
IronMick is offline
... Brad in Tavistock
Is that Tavistock ON, Canada?
Old 11-03-2009, 05:43 PM
armybradarmy
Stage III
Thanks piniongear, that was just what I was looking for. Yes its Tavi in Ont. This forum is my new go-to place for info. Later
Old 11-03-2009, 06:19 PM
IronMick's Avatar
IronMick
IronMick is offline
... Yes its Tavi in Ont. ...
You know i am in London. One of my other hobbies is hiking. From time to time we hike the Avon Trail, and i pass thru Tavi on the way to some of the hikes. It may be too cold to ride up your way now, but we could get together in the Spring - compare bikes, tell lies, etc.
korey
08-30-2020 03:46 AM
Iron Man73
Ironhead
03-22-2012 07:39 AM
ELVIS996
11-16-2010 06:44 PM
genodgeno
04-02-2010 10:42 PM
Bluerose
07-06-2007 08:16 PM
Quick Reply: 1958 dry clutch
