Daymaker
When delivered to me the Daymaker on my M8 was adjusted so low it was horrible riding at night. I had the first service done while on a trip to Deals Gap and asked the dealer to have a crack at adjusting it. Once adjusted properly I'm damn pleased with it. I ran Daymakers on my last Road Glide and this single setup seems comparable in performance.
I was inquiring about the main headlight itself, not the running lights. I have an FLHTPI, a police bike, The running lights are on a separate switch and are not controlled by the high or low beam. The headlight on low projects just past the front wheel. The high on goes out maybe 20-25 feet, totally unacceptable. When you go into a curve you loose about half that distance. I don't understand it, My auto has projector type bulbs and it throws a beam as bright as a locomotive. These should be better.
I have a 17 Ultra Limited flashed so that the running lights are always on regardless of low or high beam. I find that the light provided by the Daymaker with the running lights is very good. The high beam provides little extra light over the low beam. I rarely turn it on and usually turn it back off as the difference is barely noticeable.
In other news, I absolutely love the M8 and the bike in general!
albngore
Apr 7, 2017 10:22 AM
