Inner cam bearing tool
Has anybody found a cheaper cam bearing installation tool than Jim's? It doesn't look like George's Garage has one yet. I may be in the market for such a tool in the next year or so when the warranty is close to done. I may try to make a new plate using a cam cover gasket as a template and re-use the bolt and bearing adapter from my twin-cam tool. The trick would be to line up the hole just right.
Uh, that's pounding. I prefer pressing. Case damage would be very, very, very bad. If you're taking a hammer anywhere near the inside of the engine, you're doing it wrong. Nope.
Campy Roadie (02-12-2019)
[QUOTE=BezerkoBob;16701541]Why won't this work? And then use the old cam to drive the bearing into place? Haven't opened up an M8 yet so I am curious.
That's a good idea. I didn't personally try using the old cam but cannot think of a reason why it would not unless the shoulder isn't contacting the outer cage properly. The interference fit is not that great so if a case were to break with this little effort you have bigger problems.
I've gotten all my special tools from Georges Garage in the past, I'm sure he's working on the new M8 tooling. I'll give him a call and get back to you guys.
"If you're taking a hammer anywhere near the inside of the engine, you're doing it wrong"
I agree 100%, and will wait for the proper tool.......
Puttnutt24 (10-05-2017)
