Who has done a SEPST auto tune?
#141
Thanks for posting your experience! That is good to new! I do not understand why people are stating that the canned stage 1 with new dyno tune or auto tunes run worse the stocks. So that makes me worry that I'm buying a brand new bike and going to worsen the performance and gas mileage.
I ordered Thundercone slipons made by Thunderheader gonna give them a try just for sound. If I loose any torque then I'll put on an FP3 tuner.
I'll post results when they get here.
#142
To be honest I'm going more for looks then performance with the Stage 1. I like the looks of the 4.5" SC mufflers with the slash tips on the extended bags a lot better then the stock mufflers and I like the Ventilator AC over the Stock housing. May seem silly to some but I'm going for looks versus performance. I'm satisfied with how the M8 runs stock and it seems to run just as strong as my 110" motor on my Fat Boy. My biggest concern is I do not want to effect performance and mileage by gaining some looks. From what I'm gathering here is the canned stage 1 map is just ok but leaving some performance on the table. To take full advantage of the Stage 1 map to have it dyno tuned.
#143
There is a dyno chart that shows before and after Stage 1 results. The bike made a tiny bit more power with the Stage1 kit installed and no tuner. Tests were same day and same Dyno. After the canned map was loaded it lost a bit of power compared to stock. So that confirms what people have said about the canned map making the bike run worse. Next was a dyno tune with the SEPST. They picked up some power with the tune. Ended up with about 4-5 more hp and torque vs stock. The takeaway for me is if you buy the tuner be prepared to do several smart tunes or have it tuned on the dyno. There is obviously enough adjustment in the tuner to pick up some power on a Stage1 bike.
thanks
here is a link to how to run a "smart tune with a SEPST"
https://www.hdforums.com.au/Thread/620796/1
going to do that sometime this week.
dcfatboy (05-19-2019)
#144
-the canned HD tune is sloppy and rich (smells like gas sometimes per forums, my wife even noticed that)
-the bike runs better with the stage 1 eqpt with the STOCK tune, and then they flash the bike with the SEPST canned tune, and it loses HP/TQ
-when they auto tune it, it "fixes" itself.
here's the rub: the canned HD tune also comes up as a 'STAGE 2' tune: that means it is rich enough for a Cam to be used.
but since we are Stage 1 without a Cam, we need to lean that canned tune back down a notch to work with our setup.
the SEPST is "smart enough" to do that, and make the bike run "pretty dang good"
if you want absolute adjust-ability, HP/TQ, or whatever, you need a PowerVision or a TTS.
my thought process: if an extended warranty is $1500~$2000, just pay the $350 (SEPST plus cable) for the two years of OEM warranty (this makes sense if you consider sumping, tranny transfer, and all the other M8 horror stories)
if your M8 ain't pooped the bed in the 2 year warranty, then either continue to enjoy that performance level, or drop the coin for a PV (if you keep your old PV, you can just add another license for each bike for $200)
as good as our bike runs with the Stage 1 and SEPST canned tune, we are going to Auto Tune it a few times over the next few weeks, call it good, and keep the warranty, and in truth, prolly never worry about it again.
#145
I have tuned my other bikes with either the PV or the FP3. On my new 19 RGS I am going with the Harley pro street tuner and the smart tune only because I want to keep my warranty in tact and there are no good tuners within 200 miles of my home. I know I will be leaving some numbers on the table with the Harley tuners but I bet it will run plenty good for me.
thats my thinking. Let’s hope I’m right.
#146
critter85
13
07-18-2018 09:00 AM
