3rd M8 Engine upgrade - Yep about to do it again!
Yep but it takes months if not years to get the settlement. And the law only gives you the depreciated book value of the motorcycle with the miles already on it. Sounds good in theory but I’d rather they keep replacing engines and stage IV kits till they get it right.
Received 14,658 Likes
Well best of luck and sure hope this all works out. My hat is off to you for exhibiting the patience you have throughout this ordeal. It is times like this that a person can really appreciate having a 2nd bike. Time is never on my side and need a bike to ride when I have the opportunity.
So some of you are aware that I'm on my 3rd engine on my 2017 CVO Limited. I won't go through the gory details but for thoses that are interested, you can read it here https://www.hdforums.com/forum/milwa...ddressing.html
I've had this 3rd stock 114 engine since Aug 2017. It runs really well and I'm confident in my ability to induce sumping however all efforts on this engine have shown no signs. It really runs great in all conditions and temps. But of course its still stock.
The MoCo has owed me a Stage IV upgrade under the factory warranty since last summer due to the previous 2 engines (stage IV) failing due to sumping. They made good by providing me a free 7yr ESP including the Stage IV upgrade. I waited through the winter to see if additional changes/or modifications were made to the Stage IV kits.
Obviously they have continued to make changes to the oil pump but otherwise there have been no further changes to the kit. So it goes back into the dealer shop for the stage IV upgrade to this 3rd engine. The install will be supervised onsite by the HD dealer rep and with support from MoCo Tech support. The install should be relatively straightforward using the latest instructions for installing the most current oil pump. I've attached pics of this latest oil pump version for those that are interested.
Hopefully a better outcome on this upgrade.
Do not put that oil pump in your bike it is the wrong one for the 117ci Stage IV.. The box # is correct yes but the pump casting needs to be a (last 3 digits) 180.. the 62400144 is for the 114ci true, but not for the 117ci Stage IV.
The following 4 users liked this post by Ultra61:
When they put my VIN into the sytem, they confirmed that for my Stage IV 117 build it requires a “Gen 4” oil pump with a casting # that ends in 180.
My dealer had ordered the correct part # from SB1450. How are dealers or anyone for that matter, suppose to order the correct oil pump? My recommendation is that no one should upgrade their oil pump unless their dealer has called the VIN in to HD Tech Support to ensure the most current and correct pump is being ordered.
HD is overnighting the correct oil pump for delivery to my dealer tomorrow morning. Thank you again for the information. I will post pics of the Gen 4 oil pump after it arrives.
Ultra61 (05-02-2018)
The following 2 users liked this post by Greezey Rider:
Campy Roadie (05-02-2018),
Steve Helton (05-02-2018)
