Fan assisted oil cooler question
I purchased one of the oil cooler fan kits this week from Boardtracker HD for riding in the summer heat here in NC. Quick question for those who have done theirs themselves. This might be a really stupid question too so don't laugh too hard lol. I am going to remove the clamps at the at the OEM cooler and reuse the oem lines since they are exactly the same as the new ones on the cooling fan. After I put the hose/clamp one the bottom side of the cooler, do I need to fill the cooler up with oil before puting the top line onto the cooler? Or just let the oil pump fill it up when I start the bike? Also anyone have any tips/tricks or know of anything special you need to do while installing the fan?
Just let the oil pump fill it next time you crank up the bike. It’s more of a mess than it’s worth to try to fill the cooler before putting the top hose on. Your oil level may drop very slightly but not enough to hurt anything at all. Just go for a ride and check the level when you get back. Top off if needed.
I don't know/don't think they will flash it without the fan being on there in case it comes in after the service.
Installed mine when I did the 15K service. No need to fill the cooler. I also reused the right side oem hose but changed the left side. I aiiached it to the cooler before I mounted it. Made it a little easier.
When I picked up the part I asked the service writer to flash the ecm. He said it couldn't be done until the new cooler was installed.. Said the ecm needs to "see it". I call bs the connector is only power and ground. Since they did it for free I didn't argue with him.
I am pretty sure he is referring to #26800095. Only reason I didn't go that route is because I heard of someone having to cut tabs off oem cooler with a dremel. Also part number for oem cooler and the one one in the kit are 2 different numbers so to me that means they are different
