Sumping solved
I would have expected that the SnS pump would cure or at least reduce the issue.. I wonder if in the attempt to use the SnS pump, something was missed. Maybe a leaky pump to crankcase O ring? It's also possible that something like excessive ring/cylinder leakage is screwing things up. Adding the seal on the pack of the pump pressurizes the crankcase enough to blow the oil out through the pump?
Would it be possible for you to post pics of the plate and seal?
The following 9 users liked this post by lp:
Campy Roadie (09-25-2018),
G'day (09-29-2018),
INJEKTER (09-26-2018),
klammer76 (09-25-2018),
madmat (09-25-2018),
and 4 others liked this post.
The above part number is a "suggested" part while doing stage 2,3,4 kits on the MOCO websight.
https://www.harley-davidson.com/stor...107ci-to-114ci
rubicon_ed (02-08-2019)
The following 3 users liked this post by lp:
