View Poll Results: change in engagement after recall performed
No change - engages near end of lever travel
63
90.00%
Engages earlier
10.00%
Voters: 70. You may not vote on this poll
Clutch Recall Poll
Clutch Recall Poll
track observations/experiences on clutch behavior before and after recall..after I reported mine engaging sooner there have been comments stating the prescribed change from the recall shouldn't allow that if performed correctly so interested in hearing about results
edit: should have added change in freeplay as an option after the report of being very sloppy from member, but apparently won't allow me to edit the poll..anyway, there is no change in ours, tension and pressure is required immediately when pulling in lever, same as the day we bought them
Max Headflow (11-15-2018)
well that was my first thought but I don't even see an edit option on my post anymore, let alone an option to delete the posts and I went thru the profile settings and options..so please feel free to share how to do this if you are aware of how to as I gave up
edit: SW said the change could simply be bike to bike variation with the 'change' introduced, and is what it is..they performed the recall per instruction, bleed, checked clutch dial indicator, etc..I'm satisfied all is well and good
