About those M8 oil jets
When the sumping issue was first being discovered on this board, there was some talk about loose oil jets. And poorly designed oil jet gaskets. Haven't heard that mentioned in awhile. And never heard if it was a common issue. Was it ever a big deal? Oil jets are such simple devices its not something you would ever expect to have to address
hi when I thought my bike was sumping they pulled the motor apart and found a extra oil jet bolt floating around that got in the oil pump they ended up with a lot of new parts crank cam jugs oil pump pistons rings I think the only thing they did not replace was heads
been running great since
2018 triglide
2018 triglide
2018 triglide
2018 triglide
Glad they squared you away and you're running right.
I have done the factory tour 5 times, 4 to the Kansas City plant and once to the engine plant in Wisconsin and not once have I seen any body on their cell phone. In fact just the opposite, every time I have been there it looked like a very clean and well ran facility.
rscott (12-28-2018)
