2018 FatBoy S&S 475c Cam
Old 01-22-2019, 02:31 PM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,519 Likes on 2,137 Posts
Originally Posted by DTTJGlide
You probably need more back pressure to iron out that dip down low, you might be able to put some kind of restrictor in that pipe & make it work better, the S&S 475 is very particular about exhaust & tune.
Agree! I had a similar low end dip on my FXR’s sheet, using a Bassani Road Rage pipe. Installing the “quiet” baffle introduced just enough restriction to smooth it out nicely. And the quiet baffle isn’t that quiet lol.
Old 01-22-2019, 02:51 PM
Rican219's Avatar
Rican219
Rican219 is offline
Perfect that is what I'm doing then!
Anyone want to buy a supertrapp?! LOL
Old 01-22-2019, 03:18 PM
DTTJGlide's Avatar
DTTJGlide
DTTJGlide is online now
Since it's a Supertrap it should be able to be tuned by removing discs or changing to a closed end cap, one way or another you're probably end up with a quieter exhaust if you want to get rid of the dip.If you like the way it sounds now I would just leave it alone, with a fairly light bike you shouldn't feel that dip that much anyway.
Old 01-22-2019, 03:22 PM
Mchad's Avatar
Mchad
Mchad is offline
Not all Supertrapp exhausts use the disc system. This one seems not to.
Old 01-22-2019, 03:33 PM
Rican219's Avatar
Rican219
Rican219 is offline
Correct no disks here
Old 01-22-2019, 04:45 PM
Hardcase61's Avatar
Hardcase61
Hardcase61 is offline
I vote for the D&D,I had a bassani on a 2017 street glide with SE stage 4 and it seemed to hold it back changed to a D&D and it ran better, i currently have a 2018 heritage (see sig) with a D&D and love it.
edit for sig not showing.
2018 Heritage Classic 114 (Vivid Black), stage 3 (now 117) SE tuner, SE smart tuner pro, D&D Fat cat straight back
Freedom dark grey tint 19 inch shield.
JES Custom Accents fork deflectors in black.
Old 01-22-2019, 05:58 PM
Bowhunter8607's Avatar
Bowhunter8607
Bowhunter8607 is offline
What about adding a Thunder Torque Insert to help with the dip? You may be able to get rid of it without buying a whole new exhaust.
Hardcase61 (01-22-2019)
Old 01-22-2019, 07:44 PM
Mchad's Avatar
Mchad
Mchad is offline
good point, may be worth a try OP. Give DK Customs a call and they’ll help you pick the right one. Measure your exhaust for the call...
Old 01-24-2019, 09:12 PM
Rican219's Avatar
Rican219
Rican219 is offline
So I purchased the Bassani Road Rage the tuner said that they have seen good performance out of those. I will post up once I get it installed and get retuned on the Dyno.
Anyone want to buy my Supertrapp? LOL
Old 01-26-2019, 12:06 PM
Bowhunter8607
Which Road Rage did you get? Be aware that this one is easy to scrape and touches down before my peg does. Not sure if the Fat Boy will be any different. Just something to think about.
The Road Rage in the top Picture sits much higher and most likely won't scrape in the corners.
Quick Reply: 2018 FatBoy S&S 475c Cam
