Lifter noise
Lifter noise
Ok people just completed my stage 2 107 build using the S&S 475 cam S&S premium lifters, Fuel Moto adjustable pushrods with PV tuner and target tune. Also the Fullsac head pipe and TBR slip ons.
Bike sounds good but loud at the rocker boxs.
Fuel Moto guys said give it some miles and should get quiet, they did not.
Wrote back and another tech says there should never have been noise??
He Suggested I check my adjustments of 4 complete turns + 2 flats, I know I adjusted them right but I'm going to double check.
My question is this, do I bring all the lifters to zero lash and let them rest a while before adjusting again or bring them to zero lash and tighten right back again?
Hopefully this makes since, thanks.
Always, did my 3 heat cycles as recommended from FM and then took her out for a 30 mile ride in sunny 40 degree weather. Rattled the whole time. It would get quiter and then loud again.
I am so glad I am reading through this thread, sorry for your troubles with this but you may have saved me from the same issues. I must have an old set of a installation instructions that have the adjustment at 3 turns + 1 Flat, After reading this I just watched the video they have and it states 4 turns + 2 flats as you all have mentioned. Is there a way anyone can post the instructions that are included with a set of these? Today being Sat, FM is closed.... Help if you can. It’s going to be 65 here tomorrrow and was hoping to fire it up and check things out.
The instructions should equal 1/2 the lifters plunger travel. In other words the lifter has a plunger in it that has a travel length, the idea is to have that push rod adjusted so the plunger in the lifter is mid-stroke. So first step is to find the length of the stroke of the plunger in the lifter. The second step is to find how many threads per inch the adjustable push rod has, then after going through the proper procedure adjust the push rod to obtain the proper location of the plunger.
Chuck
Chuck
Stud Duck (03-06-2019)
The instructions should equal 1/2 the lifters plunger travel. In other words the lifter has a plunger in it that has a travel length, the idea is to have that push rod adjusted so the plunger in the lifter is mid-stroke. So first step is to find the length of the stroke of the plunger in the lifter. The second step is to find how many threads per inch the adjustable push rod has, then after going through the proper procedure adjust the push rod to obtain the proper location of the plunger. https://www.youtube.com/watch?v=8jqJck0vQRw
Chuck
Chuck
The following 4 users liked this post by $tonecold:
GlidingJoe (02-23-2019),
neon65 (02-23-2019),
ROCKOUT Rocker Products (02-24-2019),
And they may be following the wrong instruction sheet for the pushrods they have. For example, you cannot used S&S adjustment procedures for Bender Cycle pushrods or vice versa because the tpi is different.
There are two major keys to lifter adjustment: lifter design and pushrod design.
You need to verify the specs of your lifter and pushrod to get a good starting baseline for adjustment.
Lifter design is important because it determines the total travel of the lifter’s plunger. Stock TC & M8 lifters usually have a total plunger travel of approximately 0.200” plus or minus roughly 0.020”.
For an average street motor, you want to adjust the preload about in the middle of the total lifter plunger travel, or roughly 0.100” preload. But this is not an exact science, so the middle is only a good “starting” point.
You can check lifter plunger travel by installing the pushrod spin-free in the engine, then crank the pushrod down until the lifter’s plunger bottoms out. Then count the number of turns of total pushrod travel you applied. Now set the lifter preload at one-half of the total turns of pushrod travel.
The next thing you want to know is how many threads per inch (tpi) your pushrod has. S&S and several other manufacturers use 32 tpi. I “believe” the SE M8 adjustables use 24 tpi (not sure).
The last time I checked, Fuel Moto was selling Bender Cycle pushrods (Eastlake, OH), which use the oddball metric M8 x 1.00 thread, which is 25.4 tpi (0.0394” per turn). Cruiser40, you need to verify this!
You can also verify tpi by measuring the number of threads in one linear inch. Another method is to spin the pushrod adjusting nut 10 turns and measure the distance it travels. Ten turns on a 25.4 tpi pushrod should move the nut 0.394”.
Following are the distance per turn for some common tpi:
32 tpi = .03125”/turn
25.4 tpi = .03937”/turn
24 tpi = .04166”/turn
Cruiser40, you said you have FM pushrods and someone suggested adjusting them 4 complete turns + 2 flats. If you have FM Bender Cycle pushrods with the M8 x 1.00 thread, that means 0.03937” preload per turn or roughly 0.170” total preload for 4-1/3 turns. Yeah, I know, some racers adjust their pushrods with this much preload so there is less chance for the lifter to collapse under high spring pressure, but you might want to start closer to the middle of the plunger travel and see how that works.
If the lifters tick after 20 or so miles of engine running, add another ½ turn or even 1-turn of preload to see if that quiets the lifters down.
For reference, 3.2-turns of preload with the Bender pushrod (assuming 25.4 tpi) “should” be equal to 4-turns of S&S Quickie preload at 32 tpi.
When adjusting pushrods, always make sure the lifter is on the heel of the cam lobe (lowest part) while the engine is on the compression stroke.
Good luck!
