Header pipe
Old Apr 10, 2019 | 12:21 PM
Mac daddy 103's Avatar
Mac daddy 103
Default Header pipe
Soooo,....Now I’m on a mission to ge at header pipe for my 114 M8, I do have a stage I with mk45s slipons SE AC & tuner & stage II SE cam runs real good with Good TQ (still in the breakin period) but I want a bit more sound coming out of my slipons so, my next question does it or will it if I add a header make it sound louder? And which brand ?
Someone on here must haveThe Mk45 slip ons with header..and I would like some input..
thanks in Advance
Old Apr 10, 2019 | 01:10 PM
$tonecold's Avatar
$tonecold
thanks in Advance
Have you removed the cat from the stock header? If so, that is about as loud as it is going to get. Any additional sound will be about your mufflers and the baffles that they have.
Old Apr 10, 2019 | 02:23 PM
teedoff65's Avatar
teedoff65
Yup, as stonecold said...thats about as loud as an M8 gets. You can remove the DB killers from your mk45's, but you'll lose some power that very noticeable.....to me it was anyway.
Old Apr 10, 2019 | 05:24 PM
Quik's Avatar
Quik
Two popular choices seem to be the fuel moto jackpot 2/1/2 and the fullsac MX. Both get high ratings and I'm sure either one is top notch.
Old Apr 10, 2019 | 06:06 PM
Redrodyankneck's Avatar
Redrodyankneck
I noticed you have all SE parts except for the slipons. Did you have your drive train warranty in mind when you chose those parts? Oh boy now I did it, but it had to be asked.
Old Apr 10, 2019 | 07:09 PM
mjwebb's Avatar
mjwebb
I'm wondering if in his quest for better sound with adding catless headpipes, it might change "runs real good with Good TQ" and need a retune that his SEPST won't be able to support? if so means spending money on another tuner and perhaps dyno tuning, etc.....there's compromises and solutions to about everything but they ain't always inexpensive
Old Apr 10, 2019 | 07:44 PM
Hawg Runner's Avatar
Hawg Runner
Change out the header and there goes the warranty no matter which tuner he has, if I'm right.
Old Apr 10, 2019 | 07:50 PM
OldMike's Avatar
OldMike
Indeed.
Making changes for power and sound takes a lot of planning. Since the M8 is quite new there are many new parts available.
I do a LOT of reading here on the forum.
Old Apr 10, 2019 | 08:35 PM
flstcbob's Avatar
flstcbob
If loud is what you want, you will get more decibels per dollar by switching to Tab mufflers with Zombie baffles. Even with stock headers, they would be louder than your S&S mufflers would be with a catless header. Then you could also keep your same tuner and not worry about your tune being off, and...keep your warranty.
Old Apr 10, 2019 | 08:45 PM
Wvroadglide's Avatar
Wvroadglide
I just installed a RCX tormentor a couple weeks ago. I had rcx 4.5 slip ons only since I bought the bike last fall. Now header, intake and tuner. Runs defiantly better, way way cooler. Much nicer idle and exhaust tone with the tormentor. The tormentor makes great torque. With a torque cam should be killer.
