Header pipe
Old 04-10-2019, 09:41 PM
Wmitz's Avatar
Wmitz
Wmitz is offline
Just a head up Fuel Moto just came out with a new lower priced headpipe.
04ctd (04-11-2019)
Old 04-11-2019, 09:09 AM
Bannana Boat's Avatar
Bannana Boat
Bannana Boat is offline
I see you said you are still in "break in period". I assume you must be aware that dumping the factory head pipe likely leads to a non warranty situation?
That being said, the most economical is gutting the stock head pipe. I added the fullsac header and gained 3-4 lb ft of torque down low in the rpm band and a few hp up top. It is however, a very expensive piece, so you have to question the bang for the buck.
Old 04-11-2019, 07:29 PM
Redrodyankneck's Avatar
Redrodyankneck
Redrodyankneck is offline
Originally Posted by mjwebb
I'm wondering if in his quest for better sound with adding catless headpipes, it might change "runs real good with Good TQ" and need a retune that his SEPST won't be able to support? if so means spending money on another tuner and perhaps dyno tuning, etc.....there's compromises and solutions to about everything but they ain't always inexpensive
I keep on reading that the cats flow so good on the M8 that there are little or no gains in power when removed. This would indicate to me that a retune would not be an issue. Of course it woulds all depend on how good the tune was to begin with.
Old 04-12-2019, 10:26 AM
intrepidxc's Avatar
intrepidxc
intrepidxc is offline
I went with the SuperTrapp 2-1-2 on my stage 2 build. I planned to use the Fuel Moto Jackpot head pipe, but it was back ordered for at least a month and I didn't want to delay my build. So far the SuperTrapp 2-1-2 seems to be performing well and I'm happy with my choice.
Eccool (04-12-2019)
Old 04-12-2019, 05:06 PM
mjwebb's Avatar
mjwebb
mjwebb is online now
Received 8,604 Likes on 4,451 Posts
yeah, not sure about that if they are reusing the OEM 02s etc..someone here has probably experimented or experienced with these type of mods
Old 04-13-2019, 09:07 PM
Cruizer40's Avatar
Cruizer40
Cruizer40 is offline
I can vouch for the Fullsac headpipe I run them with the S&S 475 cam and TBR slip ones and they are awesome.
Old 04-14-2019, 09:18 AM
binford6100's Avatar
binford6100
binford6100 is offline
Add another testimonial for the Fullsac MX headpipe. I’m running it along with CFR slip-ons which gave me the deeper tone and just the right volume level IMHO. I had the tab zombies and the MX headpipe just made those a little too much over longer interstate trips.
Old 04-15-2019, 06:15 AM
pittz5's Avatar
pittz5
pittz5 is offline
hows the performance with those CFRs? Lose bottom end?
twitchcvma
2014-2023 Touring Models
01-02-2020 01:14 AM
Kevinch
31
01-15-2015 11:49 AM
BamaBoyjc
04-21-2013 07:05 AM
jbleim
02-07-2011 10:23 AM
jcc/tx
03-27-2005 12:10 PM
Quick Reply: Header pipe
