M8 burned oil and loss of power what does harley do in 2019
While a stock M8 107 has a lower probability of sumping based on reported examples, there have still been numerous examples of stock 107s that have sumped. In fact, there have been a fair number of posts reporting stock Trikes that have sumped. Perhaps the additional drivetrain load and weight contributes to potential sumping conditions.
Where did you get the “1%” figure from. Is that just your personal “SWAG” or a sourced data point?
BUT, it seems to me, that the odds of his dealership failing to set his bike up properly before delivery (as an example of what can go wrong) would seem greater than what he posted. I don’t know him, I have no reason to doubt him....but this just seems ....well......odd.
ill be anxious to follow his saga.
Received 19,647 Likes
Absolutely a SWAG. I hear what you are saying, and won’t be stunned if the OP is experiencing both phenomena simultaneously on a stock engine within the first month of ownership after operating it at 60mph.
OP, I have read somewhere there were s few early 19’s that came through without the o ring for the new style pumps. It may be as simple as that. Get the build date if you can. Also make sure they do a leak down test on the engine before and after they pull it apart. HD (factory) is noted for not replacing cylinders/pistons/rings unless there is a 10% leak down. Mine had a 5% leak down on the rear cylinder, with some light scoring on the cylinder and piston and wouldn’t replace them. How many miles on the bike?
Ahh....see....you misunderstood. I wasn’t trying to infer that a dealer had done anything to create sumping, just that general mistakes can be made in set up that could cause issues. Difference here is I’m not assuming it is sumping while at the same time keeping an open mind that it could well be. My only attempt here was to say that in my untrained view of the issue, the odds of setup shortcomings or mechanical anamolies at delivery are at least as good as sumping/transfer within the first month of ownership. We’ll just have to wait and see what the outcome ultimately is.
Can you share a "general mistake in setup" that you believe could cause the symptoms the OP described?
I honestly don't believe I misunderstood you at all. Given his description of the symptoms, there is no other conclusion I can reach other than the engine sumped rather severely. And there is nothing in a dealer's prep & setup process on a newly delivered bike that could inadvertently induce an engine to display the symptoms described.
