What oil in a new M8?
Old 06-20-2019, 08:34 AM
Superdog3:16's Avatar
Superdog3:16
Superdog3:16 is offline
Default What oil in a new M8?
I bought a brand new softie last fall. Got 1k service comming up. Undecided on whether to do it myself or not? Anyways, my question is:
Do most people switch to synthetic, or stay with regular?
Old 06-20-2019, 08:37 AM
Harttoo's Avatar
Harttoo
Harttoo is offline
Most go synthetic.
Old 06-20-2019, 08:40 AM
mjwebb's Avatar
mjwebb
mjwebb is offline
Received 8,604 Likes on 4,451 Posts
stay with regular...and we're off and running !!!!!!
The following 2 users liked this post by mjwebb:
Silentgreyfellow (06-20-2019), strych9 (07-02-2019)
Old 06-20-2019, 09:04 AM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,458 Likes on 755 Posts
Most folks I know go with syn, I do not.
Old 06-20-2019, 09:15 AM
Dynamick's Avatar
Dynamick
Dynamick is offline
Not a Moderator!
Received 6,687 Likes on 3,237 Posts
Not wanting to take any chances, I use half-and-half
Old 06-20-2019, 09:16 AM
sandrooney's Avatar
sandrooney
sandrooney is offline
I use regular.
Old 06-20-2019, 09:35 AM
KrustyKush's Avatar
KrustyKush
KrustyKush is offline
I've used Syn3 in the engine since the beginning.
I recently, at 19k miles, changed over to Syn3 in the transmission and primary. I hadn't really intended to make the change in those two holes, but when I had my primary vent installed at the dealer, the tech put Syn3 into the primary. So I went ahead and changed out the transmission, too, when I got home.
I've now put about a thousand miles on the bike since then, and can say that there is absolutely no detectable difference in operation of the motor and transmission with the Syn3.
I've been using synthetics, mostly Mobil 1, in all my motorcycles for over 30 years. I like synthetics because I ride year 'round. One of the best features of synthetic oil is that it doesn't thicken up as much in cold temps. Flows better, faster. Also, is reputed to resist breaking down in high heat. These HD engines certainly do run hot!
Old 06-20-2019, 09:47 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,526 Likes on 4,628 Posts
Originally Posted by Harttoo
Most go synthetic.
How do you know ?
Old 06-20-2019, 11:06 AM
FLTRI17's Avatar
FLTRI17
FLTRI17 is offline
Since we’re talking an air cooled engine (some with help from liquid cooling) there is a rationale for using synthetics over Dino because syns deal much better with temperature swings from ambient to 400+ degs as the oil passes through the cylinder heads. No downsides to synthetics just upsides.
Bob
Old 06-20-2019, 11:21 AM
Screamin beagle's Avatar
Screamin beagle
Screamin beagle is offline
Received 4,009 Likes on 2,001 Posts
You've put a 1000 miles on since last fall? Unless you live in the arctic circle or a rain forest that's a pretty low number of miles. After changing the oil ... promptly have the bike shipped to me for some actual mileage to be put on it. In your case you should go synthetic since it's going to be in the bike for about 3 years before you hit the 5k service. Yes I'm d-bag...see ya at the rally.
EdsRoadGlide2017 (07-03-2019)
Quick Reply: What oil in a new M8?
