Cheap DIY preventative for M8 Oiling problems
None of my riding buddies have a problem with their M8 and many are rocking the earliest 107 M8. However, none are into performance mods except me and I am already losing sleep over the 128 big bore kit from SE, hence the reason for my concern of potential sumping/transfer as I have read that most sumping problem comes from stage 4 and above M8s... upon reading the answers from the good folks here I think you guys are partially right, I’ll probably just install the 22XE cam, up the comp to 10.75:1 and just ride it like I stole it until something blew and when that happen I’ll just rebuild the engine with 128” kit and install all the necessary preventative measures/fix for the sumping/transfer.
why do people spend 20 to 30 thousand dollars on a Harley and then want to do “cheap redneck fixes” on them? I’d replace the pump with the 8 lobe pump and the seal, it might not transfer so I wouldn’t worry about it until it does. My 2017 has 34k on it, never has transferred a drop.
Problems with these bikes are completely blown out of proportion because a forum only attracts people that have had issues. None of the people I know with M8s have never had any of the M8 issues. Except me, but I beat on mine
The newest oil pump is the best solution for sumping, along with venting the crankcase to atmosphere. That said, if you are doing a big bore kit, ALWAYS check that the oiling jets are not leaking and are torqued correctly.
As far as the transmission fluid transfer issue, I offer the following advice.
1) Don't waste your money on the "fat rod" fix, it is not a 100% fix for all M8's that experience the transfer issue. It did not work on mine, and I proved that by using a UV dye kit.
2) The vent kit is also not a 100% fix for all M8 bikes. (As noted by a few folks across various online forums, and one person I know personally.)
My 2018 RG CVO did not experience the transfer issue until it had about 3k miles on it. After trying the "fat rod" fix and realizing it didn't work, and BEFORE HD came out with the vent kit. I went a different route after understanding how the transmission is supposed to vent pressure. As well as watching a video posted showing how the trans fluid interacts with the trans side cover.
Without getting wordy and technical.
Make your original trans cover, that looks like this.
And make it looks like this.
In essence, trans fluid cannot transfer thru the clutch push rod channel, if it cannot reach that level in the first place.
I installed my last modded trans cover on my brothers Ultra last month.
I have two trans covers that I need to put on the mill and modify, but I have way too many other non-motorcycle projects going on right now. (I also don't own a mill, I use my gunsmith's mill and he is currently backlogged with work.)
That said, look at the pics real carefully, it is pretty obvious the difference between stock and modified. Essentially, the concave portion of the trans cover is removed, and passages are cut to allow fluid an easier, non-restricted path to drain back into the transmission, instead of pooling up on the concave portion of the trans caver, thus, fluid will never rise to the height of the push rod channel, thus transfer cannot occur.
eta: I do not sell these nor do I do this mod to make extra money. Too much of a headache. I only do it for friends and family that have the problem as I am not "in business".
I cannot, sorry. I don't have anymore pics saved.
I have use of a mill, so that is what I used.
Here is another picture with an AIM clutch slave cylinder bolted to the trans cover.
Gordon65
05-07-2010 04:33 PM
