Dynamic inserts/baffles
Old Sep 19, 2020 | 03:49 PM
mikeo33y's Avatar
mikeo33y
Default Dynamic inserts/baffles
anyone try the new fuel moto dynamic tunable inserts? I have a sidewinder 2 into 1 exhaust and was wondering if they fit. For 50 bucks i figured id try them. show 20 ft lbs added at 2200 rpm on website.
Old Sep 19, 2020 | 07:16 PM
NorthWestern's Avatar
NorthWestern
I have them in my Rineharts, I have no idea of the exact fit in a Sidewinder, but Jamie has several posts about them in different pipes. Just give a quick search.
They do quiet the pipe down quite a bit, just so you know.
Old Sep 19, 2020 | 10:35 PM
BatOuttaHell's Avatar
BatOuttaHell
Running one in my FM Road & Track to restore a bit of low end that I lost. You can adjust the tab to allow for more/less sound and more/less back pressure. Happy with it but would rather the R&T not have the low end issue to begin with. If it wasn't such a great sounding pipe I'd have tried something else.
Old Sep 20, 2020 | 08:42 AM
mikeo33y's Avatar
mikeo33y
dont want quieter. want a little louder with more torque. if i remove the stock insert my exhaust is louder but definitely less tourque. looking for louder with more torque if possible with the same system. also as a side note i have the catless sidewinder
Old Sep 20, 2020 | 10:16 AM
NorthWestern
Louder and more torque does not compute. You can certainly ask FM to make sure what the difference would be with yours.
I removed the stock, 12 inch long, perforated baffles from my Rinehart cans and installed these. They are now quieter. i miss the old sound, but I do like the dyno number.
I too have a catless performance header. Mine is the Rinehart Slim Dual
Old Sep 24, 2020 | 12:20 PM
robbie52's Avatar
robbie52
Northwestern
Did you install the short tunable insets in your Rinehart baffles?
Old Sep 24, 2020 | 03:31 PM
1badharley's Avatar
1badharley
Originally Posted by robbie52
Northwestern
That is what I did.....If I remember correctly...that is the only way you can do it.
Old Sep 24, 2020 | 08:07 PM
jimmmya's Avatar
jimmmya
I ordered the Woods 222X-E and FM said the inserts will make my Rienharts perform well with the cam
Old Sep 24, 2020 | 08:09 PM
NorthWestern
Northwestern
Yes...took me a minute to remember what the hell I did
Old Sep 24, 2020 | 08:46 PM
jimmmya's Avatar
jimmmya
yes the youtube FM video shows removing the baffle and screwing insert to it
itsmf
Jan 8, 2017 11:37 AM
DanTheBetterMan
Nov 8, 2016 08:48 PM
JohnJameson
May 2, 2012 01:28 PM
tmitchellof PG
Jan 28, 2007 05:48 PM
Axholio
Jan 29, 2006 01:17 AM
