Anyone else running NGK CR9EIX plugs?
Old Oct 7, 2020 | 05:10 PM
martin10's Avatar
martin10
Default Anyone else running NGK CR9EIX plugs?
I usually stick with stock plugs. But since it's a pain in the *** to change the right side plugs I went with the longer lasting iridium's. I just pulled the left side plugs. They look like the bike is running too rich. Nothing has been changed tuning wise except the plugs. I triple checked the plug part number. Anyone else run into this? Maybe the M8 doesn't like these plugs
Old Oct 8, 2020 | 12:12 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
How long was the bike running before the previous shutdown when you looked at the plugs? If not very long (i.e. not up to operating temp), it would most likely be running rich. I've always been told with EFI you don't look at the plugs to know if you're running rich/lean, you look at A/F ratio.
Old Oct 9, 2020 | 08:46 AM
otterhigh2's Avatar
otterhigh2
Twin cams used the plugs to detect knock and most guys ran stock plugs for that reason. The M8s apparently use a separate knock sensor, don't know if the system is tied to the plugs or not though
Old Oct 9, 2020 | 08:57 AM
mjwebb's Avatar
mjwebb
Originally Posted by otterhigh2
I'm all for aftermarket almost anything, but the 3 things on these bikes it's probably not a good idea to get away from stock on are plugs wires and coils. Delphi Harleys use an ion sensing system to retard timing and prevent pre-detonation (knock). The system senses extra ions in the cylinder before the knock and sends feedback through the plugs and wires and it is tuned to the stock plugs and wires. Most don't have a good experience using aftermarket plugs or wires.
I think all that was true pre M8...but the ECM and everything that goes along with the EFI, etc. changed with M8s...still agree with "not a good idea to get away from stock on are plugs, wires and coils" ...they just work so for me not worth experimenting on
Old Oct 9, 2020 | 09:02 AM
otterhigh2's Avatar
otterhigh2
Yeah I just corrected myself
blackflame
Oct 25, 2014 10:04 AM
Herksuper
Aug 16, 2011 06:59 AM
stuntdad
Nov 17, 2010 05:28 PM
spankustang
Exhaust System Topics
May 19, 2008 04:38 PM
gigiflip
EVO
11
Sep 14, 2007 07:59 AM
