131 kit installed and have a question for an expert like Steve Cole
The non 110 twin cams did not have many lifter failures. The 110 twin cam, lifter failure was not a question of if, but rather when. It's part lifter problem, part cam problem and very high valve spring pressures on the 110.
I agree, Built the motor in my 19 with 21K on the bike. When aftermarket, knowing I would be voiding the 10 months remaining powertrain warranty. No regrets. No engine or trans problems in that 10 months, bikes now 2 years old.
I sure have not heard of many lifter failures in the M8 engines.
What engine? An M8? curious
Not saying Harley lifters don't fail.
I have not heard of lots of lifter failure on the M8 like the 110 engines. I know many M8's with over 40K miles with out lifter failure, I know very few 110's with out lifter failure before 40K
TC that were not 110 did not have a high rate of lifter failures like the 110
So why did he put new lifters in to begin with? Failing in a few hundred miles could well be an installation issue.
The problem with the moco is that if your clutch basket explodes or your transmission fails, belt breaks ect.. They will blame the Tuner instead of their shitty products. I see why he wants to keep the warranty, myself. the very first **** I take I wipe my *** with it... It means nothing because they can delete your warranty at anytime by simply saying "you ride the bike to hard".
Get Discount ESP and do a PV tune... Discount ESP is less than 1K for 2 years past your factory warranty.. If you still have warranty then it will work if HD denies claim.. So basically if you bought Discount ESP when you first bought the new bike you'd get 4 years total... I know doesn't answer you question totally but is an option.
